View all of the ACE IPv6 entries associated with an ACL.
- The ACL exists.
- The ACE exists.
- Select Advanced Filters (ACE/ACLs).
- Select the ACL tab.
- Select the appropriate ACL.
- Select ACE.
- Select the appropriate ACE.
- Select IPv6.
- Select the IPv6 tab.
IPv6 Field Descriptions
Use the data in the following table to use the IPv6 tab.
| Name | Description |
| AclId | Specifies the ACL ID. |
| AceId | Specifies the ACE ID. |
| SrcAddrList | Shows the source IP address. |
| SrcAddrOper | Shows the operators for the ACE IP source address. |
| DstAddrList | Shows the destination IP address. |
| DstAddrOper | Shows the operators for the ACE IP destination address. |
| NxtHdrNxtHdr | Shows the next header of the IPv6 header. |
| NxtHdrOper | Shows the operators for the next header. |
| TrafficClsOper | Shows the operators for the traffic class. |
| TrafficCls | Shows the traffic class attribute of the IPv6 header. |
| SrcAddrMask | Shows the mask value for the source IP address. |
| DstAddrMask | Shows the mask value for the destination IP address. |
